メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Replacement screen not sitting in on bottom right
This is probably a common issue for aftermarket screens.
Is there any particular reason why it happens? I tried two screens from different suppliers and the same issue occurs.
Also the iphone housing is in excellent condition, no bends or dints on frame.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Hey, if you check the flex on the screen that goes to the motherboard, there is a metal part on it. that part probebly hits the motherboard or anything else nerby.
see this picture:
https://d3nevzfk7ii3be.cloudfront.net/ig...
the flex should lay as this one does a little bit from the metal part on its right side and not to high up.
I have had this problem twice before and that helped.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
thanks so much that worked, i had to flatten it out because that rectangular brick slides out of place and it fits in a small rectangular hole and if they dont match the corner comes up
さんによる
コメントを追加
Hi Ben
You are one of the great sages, but if it were not so, I would say:
Something similar happened to me once. I would say it has to do with the fasteners in the frame of the screen or the thickness (too thick) of the frame.
I have also seen chassis bent in strange ways, it is not necessary a blow, with enough pressure can affect.
Another screen or reinforce the adhesive on that part could help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi there is a possibility that your iPhone's rear housing is bent it's a very common issue with the iPhone after been dropped on the corner or kept in tight Jeans so it may never fit properly. you can check by placing it against a flat surface (making sure the camera is not in the way) and check if there is any gaps between the surface and the phone if there is you have a bend, sadly a rear housing is such a pain in the arse to replace even apple just replace the whole unit for exchange price which dose vary if you go to a Apple Sore or Apple reseller i would not trust a corner shop with this job.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ben さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,013
