Why is my iPhone 5s can't activate?
My iPhone 5S touch id was suddenly not working and i forgot my passcode and so i restoring my iPhone and after the restore is done i can't activate my iPhone it says "Your iPhone could not be activated because the activation server cannot be reached. Try connecting your iPhone to iTunes to activate it," so i tried to activate my iPhone iTunes and the notification popped out saying that "The iPhone could not be activated because the activation information could not be obtained from the device. Disconnect your iPhone, make sure the SIM card is inserted correctly." even though my the SIM card was inserted from the beginning.
I was tried restoring many times but it still failed with the same notification. And my last try was contacting the Apple and they said probably it's the hardware problem. Please help me if anyone know what is the problem. Thanks before.
Any solutions so far? I still could not solve this problem even though it has persisted for 5 months since December 2017. I am using iPhone 5s
Gusion Lim さんによる
Please kindly share info if you have solved the problem, mine is refurbished tho
Erwin Husni さんによる
I am having the same exact story problem with my iphone 6s.
Some technician says that if your phone refurbished, then some of your repaired components couldnt be detected by iphone.
Hence, this problem.
Please help me with this issue, if someone can solve this thing.
Erwin Husni さんによる
