My printer is saying paper jam with a loud noise
My printer is saying paper jam with aloud noise, why can I fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It will either have a latched door at the back or the bottom of the unit, to remove any stuck paper that may have jammed up the mechanism. Try looking for and opening that door and cleaning out whatever may be in there.
このアンサーは役に立ちましたか?
Thank you this worked for us!
Thanks! The printer was instructing me to clear the paper from the paper cartridge/bottom of the printer... after seeing your suggestion, I opened the back of the printer and found two additional sheets stuck in the printer!
I have a Epson ET-15000 and mine is doing the same thing and making a weird grinding noise but no paper in it anywhere. I’ve reset it several times and nothing changed?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 10,148
2 件のコメント
Im having the same issue. Did you find out how to repair?
Vicky Maxwell さんによる
I am having Epson L550, it's saying paper jam error, but there is no paper jammed..
Kanimozhi Senthamil Selvam さんによる
