Fan speed after hard drive REPLACEMENT
Replaced HDD and now fans run all the time.
I remember a SW fix mentioned here and a HW fix.
Can someone point me to the HW sensor fix? Where may I find it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This will fix it:
このアンサーは役に立ちましたか?
@mayer thats a 404
Here's a better link: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade
Hi. I'm having the same issue after replacing my HDD and adding an SDD. Would I need one of these cables for each drive? Thanks.
このアンサーは役に立ちましたか?
The OWC cable replaces the sensor in the Apple HD drive.
If you are adding an SSD using this guide: Installing iMac Intel 27" EMC 2429 Dual Drive Kit (HDD or SSD) you won't need it for the SSD drive only the HD.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 117
