メインコンテンツにスキップ
Panasonic Lumix DMC-FZ35 High-end Digital Camera - Black DMC-FZ35K 31
4回答 すべてを表示
Dead, no power on
I have the Panasonic Lumix DMC-FZ35 High-end Digital Camera - Black DMC-FZ35K.
I am trying to turn it on but it is not working, totally dead. I replaced the battery, tried to turn it on but no luck, nothing gets turned on, totally dead. I don't know what is the problem. Can you advise me what part needs to be replaced to solve the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Same problem - I was hoping to find a secret button combination on power-up that would put this camera into a diagnostic or reset mode.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@geomorzak there is no specific part that may have failed. You do want to make sure that your battery is okay and that the battery makes proper contact. Make sure that the battery cover closes properly and that the battery contacts are not bend, broken or corroded.
After that you are bound to have to take the camera apart. You can start with this guide Panasonic Lumix DMC-FZ35 LCD Replacement to at least get you into the camera. Of course you can also use these instructions DMC-FZ35-Disassembly.pdf
Now check your circuit boards for any damaged and/or missing components. Pay particular attention to the main PCB around IC1001 which is your power supply IC. Post some images of your circuit boards once you have it apart. We can always try and help you with further troubleshooting. Use this guide iFixitでの質問に画像を追加する方法 for that.
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Panasonic Lumix DMC-FZ35 DMC-FZ38 LCDの画像
ガイド
難易度:
中レベル
30 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
George さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 27
今までの合計 1,190
