メインコンテンツにスキップ
多様な形状、サイズ、色のAndroid携帯のための修理ガイドと分解情報。あなたの携帯電話を自分で修理するために必要なすべての情報があります。
33601回答 すべてを表示
Everything except making and receiving calls works. Please help.
I have a Le Echo - Le Max 2, which Verizon states is incompatible with its services. However, after putting my sim card in, it worked fine, with the exception of mms and making/receiving calls. I created a new APN with appropriate settings and this remedied the issue with mms, however I cannot figure out a method for getting the calls to work:
-When someone else calls me, it goes straight to voicemail, which I do not have set up.
-When I try to call someone, or dial a USSD code, it does not reach the network, and eventually gives up attempting to connect.
APN settings include:
All other settings are default.
Any and all help is greatly appreciated, thank you in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You may need to actually go to Verizon and ask them if they blocked your phones IMEI or ESN. Unlike other phone carriers, they don't like foreign phones on their network.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lucas Manteuffel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 45
