Repair guides and support for HP's LaserJet Laser Printer Line, which includes printers with model numbers starting with LaserJet, LaserJet Pro, Color LaserJet, P, M, CP, and CM.
114の回答 すべて表示
False ADF jam on HP Laserjet Pro M570dn
Hi,
I've recently got a second hand laserjet pro m570dn with an issue with the adf.
After start procedure, it says "Remove paper from document feeder".
Done this :
1) I've checked for paper or debris : I cannot see anything (I've rolled a paper manually through it in case of hidden paper piece).
2) I've disconnected / reconnected the adf from the printer : no change.
I haven't found any online guidelines to troubleshoot that myself so here I am asking about help on this :
- if there if one, where is the paper sensor that triggers this false alert ?
- do you know how to unmount the adf to have a look inside the mechanism ?
- could the printer be wrong about the origin of the issue ? ADF is not cheap so if I buy a new one, I'd better be sure of the issue.
Thanks in advance,
Regards,
Mikael
Mikael
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
It's common problem for these adf units.
Here is link. It's translated with google. It might works for you. In general - you will need to resolder (or reconnect any other proper way) cables coming from adf board to adf itself.
https://translate.google.com/translate?h...
Good luck!
この回答は役に立ちましたか?
スコア 0
コメント:
Thanks for your answer, that was a really good find !
I hope I’ll find some time to put that in practice, been busy so far…
による
コメントを追加
回答を追加する
Mikael さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 38
今までの合計 383
