iPhone X keeps restarting IOS 11.2.2 jUST UPDATED
Every 3 minutes the iPhone X keeps restarting after updating it to IOS 11.2.2. There is no way i didn't try from the previous solutions appeared in after the 2nd of December issues.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Apple store replaced the phone with new one ! As it was a hardware production issue !
このアンサーは役に立ちましたか?
I am assuming you have tried
a) Settings --> General --> Reset --> Reset all Settings
b) backup the phone fully in iTunes
• put the phone in DFU mode
• restore iOS 11.2.2 again
• do not restore from the iTunes backup afterward yet
• set up as a new phone
• then restore from the iTunes backup you just made
• do a Settings --> General --> Reset --> reset all settings again
このアンサーは役に立ちましたか?
I actually tried it but it was not helpful!
First you have to clear that there is any issue in modem firmware.Check the meid of the phone by dial *#06#.If imei shows there may the hardware issue or wait for new update coz downgrade to old version is not possible on new generation iPhone.
このアンサーは役に立ちましたか?
Modem firmware shows 1.03.06, I tried *#06# and it just gave me the IMEI number nothing else so what is the issue. the update was just made so I don't think they will update again soon.
Have you tried restoring the phone yet? Make an iTunes backup for the phone before doing so you keep your settings, photos, contacts, messages and etc.
I tried restoring but it doesn’t work
I’m having this issue too. Try turning your WiFi off. For some reason when I’m connected to WiFi my phone restarts every 3-5 minutes but when it’s on LTE it works fine. I’m going to Verizon today to try to get a replacement phone
このアンサーは役に立ちましたか?
I'm having a similar issue, but it's spread out to every hour or so. My screen will go completely black. For a minute or two, any music I'm listening through headphones, or anything I'm watching on Airplay, will still be playing. But I'm unable to do anything during this time as my screen remains black. Once what ever I'm listening too, or watching, stops playing, my screen will remain black for another minute. It will then reset and prompt me to enter my password and everything is almost back to normal. Wherever I was in my media when the screen goes black, my phone will start playing from that moment as if what I was listening too while it was black, did not happen. If that makes sense.
iPhone 7.
このアンサーは役に立ちましたか?
I have the exact same issue which you described.
iPhone X on 11.1.2 (haven't updated since I got the phone in Dec)
Update from my last post, turns out WiFi wasn’t the problem, it eventually went away but as soon as I’d restart my phone manually, the problem would come back and this past time it didn’t go away. I ended up going to the Apple store and got a replacement phone for free and I no longer ha e that issue so if you haven’t gotten it fixed yet I highly recommend you do that.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 18,675
1件のコメント
My iPhone X is still restarting after all fixes I’ve found
Jake Welsh さんによる
