メインコンテンツにスキップ
食器洗浄機の修理と解体ガイド
705回答 すべてを表示
Whirpool Dishwasher start/resume light never goes on.
I recently noticed that my start/resume light on my whirlpool dishwasher never goes on. I did put it into diagnostic mode (123...123...button pushing) but don't see or know how to read codes anyways. I did notice that all lights except the start/resume light go on in diagnotic mode. Is it possible that the start/resume light is out or has a bad connection. The washer is only 2 years old and hasn't had that much use. I also do notice that sometimes there is water in the bottom of the washer which makes me think that the cycle doesn't fully complete sometimes. I can pres drain and it will drain fine so not a clogged drain or tube problem (I've had that in the past:) Any thoughts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If you were able to get it into the diagnostic mode, and that 'Start/Resume' still did not light - you have a burned out LED. Depending on the model, this can only be fixed by replacing either the control panel or the control board. Repairclinic.com should be able to help with finding that information as well based on your model number.
I see this in a lot of cases where the light is burned out - but the button still works correctly. This is an expensive cosmetic repair if it is still working! Good luck -
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
rick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 896
