メインコンテンツにスキップ
A collection of guides and support to help with washer repair.
3478回答 すべてを表示
DRYER makes a loud noise during WASHER's final cycle
Hi
The washer is installed with a dryer stacked on top. During final spin of medium or higher, the dryer emits a loud noise which can be canceled by touching it, or by opening its door. I tried balancing the feet of each appliance, but it wasn't successful. Please advise.
I also have a video which demonstrates the type of noise it makes: https://streamable.com/xahxi
Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
John craven - the final spin cycle of the washer creates the most movement. Something is shaking something loose. Check the hoses in the back to see if they are hitting something. Make sure the mounting brackets are tight. It could be a dozen things. Without being in front of the unit I can only guess.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
John Craven さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 188
