メインコンテンツにスキップ
Repair guides and support for LED, LCD, HD and other Vizio TVs.
840回答 すべてを表示
Won’t turn on or off, vizio logo flashing , black screen, 47” tv
When I turn on power the vizio logo flashes for a few seconds, then is steady, then goes off and after a few seconds starts that cycle again. It does this over and over with me not touching anything. Screen remains black.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメント:
@mikew7 what model is your TV? What Vizio logo? The one on the screen?
さんによる
No power indicator light comes on by itself then shuts off then the only thing that power indicator light comes on and your master power button then goes off
さんによる
Mine is white n no matter what I’ve done, it continues to flash, then stops, repeat. I’ve done everything suggested except the silver cyclinder thing which I don’t have.
さんによる
vizio Hdtv will not turn off have sound, black screen, amber light not responding to any control
さんによる
コメントを追加
6件の回答
最も参考になった回答
Answer the question is symbol if it's a Vizio symbol blinking white and then yellow you going left hand side of the TV you hold it down the silver power button hold it down for 30 seconds count to 30 it'll blink and then they'll stop and we'll go stagnant yellow then hit it one more time it'll turn on just had that problem just now
このアンサーは役に立ちましたか?
スコア 4
コメント:
Mine blinks then goes solid and cycles back. I unplugged it overnight. I unplugged it held the button for 30 seconds pushed it again. I did the same thing with the power on. I let it blink all day. And I'm still doing the same thing
さんによる
I tried holding it for 30 seconds and nothing happened. Tried this several times with tv plugged in and unplugged. I was going to give up and toss the tv. But I decided to give it one more try. With tv still plugged in, I held the button for 4 to 5 minutes. While still holding the button, the tv went to solid orange and then turned on. Thanks for the suggestion. It works, but not necesarily in 30 seconds
さんによる
Tysm Tyler. Completely and totally right and this fixed my tv after multiple power surges and many different attempts at other solutions this one works. It works EVERY TIME for my Vizio at least. You rock kind sir! Have a good one !?
さんによる
Took just over one minuet for mine to reset.
さんによる
コメントを追加
I was looking for more info on the problem, but can add this. Vizio customer support is GREAT. I learned that you can unplug the tv and, likely on the bottom left side of the tv, wherever your HDMI ports are, is a silver cylinder looking button you push for at least 15 seconds. Then replug the cord. If that does not fix the problem it needs to be repaired.
I was given the phone # for their repair folks, who I was told can give me an estimate for the repair. Then I can decide if it is worth it or just buy another tv. I have to wait till Monday to call them as they are closed on Sat-Sun.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 2
コメント:
No you hold a button for 30 seconds and it should pop up it'll turn bright yellow and he hit it one more time to turn it on I just had that problem today
さんによる
コメントを追加
Just let it flash. It stopped flashing after a couple minutes and works now.
このアンサーは役に立ちましたか?
スコア 0
コメント:
You are cocky! Figure it out yourself!
さんによる
It didn’t help our situation! You are too quick judge!
さんによる
コメントを追加
On 55” Vizio, I tried several iterations of:
  1. Remove all connections
  2. Unplug Power
# 2.a. Hold silver power button down for 30 seconds
  1. Plug Power
  2. 3.a. Hold silver power button 30 seconds
  3. Unplug Power
  4. 4.a. Hold silver power button down
  5. 4.b. Plug Power — while holding silver power button for 30 seconds
  6. Upon step 4, the logo stopped blinking at around 26 seconds mark.
このアンサーは役に立ちましたか?
スコア 0
コメント:
Do you need to stand on your head while doing it?
さんによる
24 white blinks then 1 Orange. Keeps repeating. No silver button just controls on left side. Leaving unplugged for the night will check again in morning.
さんによる
we did that already. Also did all the plug and unplug power button stuff but got nowhere. I was wondering does vizio have blink codes? The blinking continues to be a constant cycle of slow/fast blinks.
さんによる
コメントを追加
My 43” Vizio did the flash and die thing when it was new. I was just getting ready to pack it back to the store but I plugged it in one more time and it restarted.
It has done it a few times in the past 10 years always coming back in a few minutes with no action from me.
Today it was out for a few hours, I took the back off to look for anything obvious and dust it out. Still nothing. I reseated the connectors, still nothing.
About two hours later it came back to life.
So if nothing else be patient! Of course it could still be dieing but a new TV wouldn't make me sad.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Power saver mode?
Motels be doing that Ive seen
Turns off, nothing but unplugging it
Like a timer
Not Vizio related..food for thought lol
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データを表示:
過去 24時間: 11
過去 7 日: 55
過去 30 日: 288
今までの合計 85,580
