メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
Battery goes from 100 to 1% in 2 hours and stays at 1% for a long time
I charge my phone, like always to 100%. Next thing I know after 2 hours my phone is at 1% with flash light on, for like an half an hour. I have no idea wtf is going on. Like I can watch one of "The Flash" episoed at 1% with flashlight on + with background music on. Like right now I'm typing this at 1% battery life with my flashlight on.....
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
3 件のコメント
And by the way i turn on my flash light at 1%, so i can kill the battery and recharge it to 100%. That`s why i turn on the flash light for.
さんによる
Do you have a Mac you can hook up to run diagnostics?
さんによる
This once happened to my small 6s and after I plugged it in the problem was solved.
さんによる
コメントを追加
8件の回答
ベストアンサー
Has this phone ever been opened or previously repaired? It kinda sounds like the gas gauge line is damaged. That would mean that the CPU is getting incorrect data from the battery regarding it's charge state.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
So what does the battery gas gauge line look like, where is it, and can I fix it at home? My phone is crazy!
The original battery had a boot-loop issue and swelled up huge (it would never show the "dead battery" red icon either) so I replaced it. Second battery didn't fix the boot-loop problem or "dead battery" either so I sent the phone off for repairs. Shop didn't know what they were doing so they just changed the charging chip which did nothing...second battery swelled.
I'm now on my third battery and I'm afraid to charge it. Batt came charged so I used it until it ran completely out. Having restart problems like Shr3kt and weird 1% jumping to 11%, back to 3%, 1%, etc.
I'm so freaking frustrated with this! Apple won't touch my phone because it's been opened.
So, gas gauge...enlighten me please.
さんによる
The gas gauge is a circuit inside the battery that keeps tabs on the current condition of the battery. This is communicated to the CPU.
If the line is damaged or the battery has a bad circuit, then the CPU will read fluctuating data and mess things up. However considering this phone has been poked around, I would suggest you find a reputable shop that does micro-soldering repairs to dig into this deeper. This is not your typical DIY fix, other than replacing the battery and seeing what happens.
さんによる
Sometimes the phone misreads the gauge. Also iPhones apply some sort of normalization to the battery level (my iPhone 6s once stayed at 16% for like AGES because the actual battery level was higher but the phone wouldn't make the gauge go up).
さんによる
コメントを追加
I dont think it is completely necessary to completely discharge the battery. However it does sound like a bad battery. Or it could also be contributed to the recent iphone update from apple. I would replace the battery.
iPhone 6s Plus Battery
iPhone 6s Plus Batteryの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had the same thing happen to me i was listening to music and it drained my battery but when it got to 1% it stayed for over an hour
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I just bought a new phone a samsung one plus phone and battery keeps draining to 1 %
さんによる
コメントを追加
If nothing else works. Open up your iphone. Disconnect the battery and then hold the power button and home button for 12 sec. Reconnect the battery and you’ll find you iphone working fine again. With me the problem reoccurs now and then but at least its fixable.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What! Hold the power switch on while the battery is disconnected! Haha!
さんによる
@Stewart Cooper
it drains any static left over (E.g also capacitor charges)
さんによる
コメントを追加
for most cases : Just disconnect and reconnect the battery and it should work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What do you mean by disconnect and reconnect the battery. iphone batteries cannot be opened because iphone case cannot be opened. Are you nuts
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
just open the screws on each side of charging port and the case can open
さんによる
I'm so confused about why Soum is here if iPhones "cannot be opened" ???
さんによる
コメントを追加
Sometimes iPhones/iPads just do that. iDevices (outside of iPods) will not allow the charge meter to go up so it’s likely the actual battery charge is/was above what it actually was (I have an iPhone 6s that has the same thing, every now and then the reported battery level tanks and the charge gauge goes to like 16% or something but the battery was actually at like 70%)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have iphone X, same thing happened after i left it to charge overnight woke up to this problem
I used it without charge on 0% battery. It shuts down after a few minutes, did this a couple of times and its back on 100. I also disabled “optimized battery charging” which i think may have fixed it.
Edit: it happened again after 30 minutes ;(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shr3kt さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 64
過去 30 日: 243
今までの合計 68,469
