メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
I am facing call drop and calling failed issues.
I am facing call drop and calling failed issues. I have even tried restore with latest firmware, also replaced my cellular sim to new one with 4G. But still i frequently face call drop issues while talking, and also when dialing it show up "calling failed" in middle of the call it gets disconnected.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
What signal strength are you getting ? Are you connected to wifi? Could it just be poor service? Have you tried resetting your phone to factory defaults?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
The problem is for cellular not WiFi, though cellular signals is poor at good locations and weak at bad locations.
Connect to WiFi doesn’t required at all times for my issue,
Poor service yeah sure, for that I have mentioned taking brand new 4G sim,
Resetting, reformatting and restoring done at multiple times.
さんによる
The reason why I asked if you are connected to wifi is that if you have wifi calling enabled it will make calls come in and go out better as long as you are connected to wifi.
さんによる
Sir, Its cellular network problem, and i think there no such option on iOS for wifi calling "enable or diable''.
さんによる
Go to Settings > Phone > Wi-Fi Calling and make sure that Wi-Fi Calling is on.
Restart your iPhone.
Connect to a different Wi-Fi network. Not all Wi-Fi networks work with Wi-Fi Calling.
Turn Wi-Fi Calling off and then on again.
Go to Settings > General > Reset and tap Reset Network Settings.
さんによる
コメントを追加
回答を追加する
nirakh shashi kanth さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 256
