メインコンテンツにスキップ
The Moto G is Motorola's economically priced phone. It has all the features one could want in a smart phone, for half the price. Model numbers XT1032, XT1033, and XT1036.
86回答 すべてを表示
Why can't I hear phone calls unless the speaker is on
I can not hear phone calls placed unless the speaker is on
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @pbplus313058 ,
Try using the earphones with the microphone attachment and listen if you can hear OK when using them on a call.
If you can and since you can hear OK when using the loudspeaker then most likely there is a problem with the phone's receiver. It's either faulty or has come loose from the systemboard
Here is a link that shows how to replace the receiver in your phone.
Here is a link to some suppliers of the replacement part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part.
If the repair process seems to daunting, I suggest that you contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Peggy Benjamin さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 25
今までの合計 1,640
