メインコンテンツにスキップ
本製品は、2010年7月27日にAppleから発売された解像度2650x1440ピクセルの27インチLEDディスプレイです。モデルナンバーはA1316。
78回答 すべてを表示
Cinema Display Shows Block of Discolored Pixels
Hi,
I have a refurbished 27" Apple LED Cinema Display that I bought from Apple in 2014. It was perfect until yesterday when it randomly showed a vertical block of pixels near the middle of the screen with some form of discoloration. I made sure the graphic card is not the suspect here by trying another display as well as using the same display on a different Mac. The problem persists, so it's something in the display.
What surprises me is the fact that these are not dead pixels; they are dynamically changing color, and can clearly be seen kind of flashing. Also, this morning I woke up my Mac to find that the display went back to behaving normally.
However, a few hours later, it started doing the same thing, with different colors. Sound is working fine.
What is the cause of the problem? And is it worth fixing?
I also attached pictures of the problem when it happened the first time.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi,
It looks like a damaged cable in the LCD, so switching the LCD would probably fix it. unfortunately those are pretty expensive, so it is probably not worth it, unless you can buy a broken LED cinema display that has a good lcd.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi Rick, thanks for your reply!
I found a few displays with a missing case on eBay, and they sell around $100-300. It looks like they have working LCD panels. But I am inexperienced in this and I don't know exactly what to look for.
Do you have any recommendations? I mean, are there any keywords you suggest I use when searching for the part I need?
さんによる
@archusain
@archusain do a search by the label on the back of your panel. that way you know that you will get an identical panel as needed for your monitor
さんによる
コメントを追加
回答を追加する
Sayed Husain Almousawi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 259
