メインコンテンツにスキップ
MBP 15" A1226: no display backlight & no sound devices.
I have multiple problems on my MacBook Pro 15" A1226. First, the display backlight does not work, however, an external monitor does work. I tried replacing the LED Driver board (bought from iFixit), but the display backlight still does not work. I have not tried replacing the inverter cable since that is unavailable from iFixit (any suggestions for other reputable places to get said cable ?) Not sure what else to try for this display backlight problem. Second, the startup chime is buzzy. Interestingly, when I open the System Preferences: Sound panel, there is NO input or output sound devices listed. I'm open to any suggestions for restoring the sound devices.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Just found a third problem, the MBP claims that the wifi hardware is not installed.
さんによる
コメントを追加
1 件の回答
Turns out the left I/O board was bad, replacing that cured the no display backlight problem, no sound devices detected, and an unresponsive left-side USB port. Power connector still worked with the bad board which led me to believe that the board was not the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hilo Boy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 61
