Back up lights not working
I found plug and play LED bulbs for my taillights I decided to use them for back up lights however it worked for a bit then stopped. I switched back to oem bulbs nothing. I tried the whole tail lights on a different jeep and that worked fine. All the lights worked fine on the other jeep. I checked the fuses all are fine I even pulled them all out and checked. I had no guide to tell me which fuse under the dash was for what so check them all. Not one of them was blown so I bought a new Neural safety switch from auto zone. Still no back up lights. Any ideas what could possibly fix my back up lights?
この質問は役に立ちましたか?
3 件のコメント
@notstnick what year is your Jeep? That way we can provide you with the proper wiring schematic and diagrams.
oldturkey03 さんによる
Hi @notstnick ,
You might have blown the circuits in the BCM (Body Control Module). Not sure re your particular vehicle but nowadays a lot of the lighting circuits are controlled by the BCM
jayeff さんによる
I have a the identical situation. 2006 Jeep Grand Cherokee 4.7L Limited.
Adam Macomber さんによる
