My ps3 won’t connect to the WiFi+my controllers
My ps3 won’t connect to the WiFi and it won’t connect to my controllers wirelessly (I have the original Sony controllers one brand new other two are quite old) any solutions? Help...
I have similaf issue with my PS3, after doing many research it seems that the Wifi/ Bluetooth chip need to be replaced or you need to do reballing for the existing chip due to the heat some time it loose connection.
I will be fixing mine in the coming days, I will inform you if it will work.
このアンサーは役に立ちましたか?
Please let me know did you fix the problem, if yes then how?
Hi I have similar problem. PS3 wifi and controllers not working wirelessly . Please let me know if you fix it
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,391
1件のコメント
I think I need to replace the motherboard but not sure
awesomekid1589 さんによる
