メインコンテンツにスキップ
2.5GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.1GHz)、3MB共有三次キャッシュ
265回答 すべてを表示
Where is the Reed Switch?
Hello.
I just bought this MacBook and it's constantly sleeping/waking by itself.
I'm wondering there's any way I can turn off the sensor and manually sleep and wake the device.
Or maybe (hopefully) there's an easy fix for this problem, and the sensor is really easy to locate and replace.
Who knows?
Hope you do.
Thanks in advance.
~LQ
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
In the top of the display. A fun way to find them is take a paperclip and run it around the perimeter of the display.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Once you find the magnet the opposing side will be where the Hall Effect transistor is located.
さんによる
There are two places at the top of the display where there's magnetism, and other two at the sides of the trackpad. I'll try with a magnet, I hope I don't fck things up doing this
さんによる
Found it, it's at the left side of the keyboard
さんによる
コメントを追加
The best way to locate the reed switch is to take an Iodinium Magnet, and drag it around the bezzel until the screen sleeps. Be sure to not go near any HDD, as this can scramble your data.
some macs have them built into the screen assembly, and some have them in the base.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
The Switch (Hall effect transistor) is located in the upper case along the edge. The magnet is located in the lid. First find the magnet and then fold the lid down the location in the case is when the lid point comes down.
さんによる
コメントを追加
There are a few possible causes for this reaction. The first is the sensor is failing so you might want to replace it.
To alter the settings look at your Energy Saver and the Screen Saver settings in the Preferences.
You might have an app that is waking or your wake on LAN is enabled so someone is probing your system. This gets into what you've installed on your system. Sometimes you install a Peer to Peer app without knowing it! This will constantly poll your network (waking) and lastly update settings can also wake your system to install updates.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Alejandro Queviz さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 19
今までの合計 1,710
