メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月に発表され、同年4月10日に発売されました。Galaxy S6 Edgeは Samsungの最新のスマートフォンで曲面ディスプレイをもつデバイスです。
Why the display turns black & flashing during charging/cellphone is on
Why the (SM-G925I )Samsung Galaxy S6 Edge just to connect to the charger and the cellphone is on ...the display´s turn black and starts to flashing ? By the way I can´t to turn it off neither anything.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
My samsung handphone screen flashing on and off while charging
さんによる
コメントを追加
1 件の回答
there are plenty of things that can cause this symptom. The basics is that it is either a software corruption, or the screen is recieving some of the charging current. this can be for multiple reasons. the process of solutions are as follows, from least-most expensive.
1) start with a factory reset, and see if it fixes the issue. (This will erase all of your data.)
2) re-flash the stock ROM to the device. (this will put new core files onto your phone. (a standard reset keeps the core files from your previous software. if there is a corruption in core files, you will not be able to get rid of it with a basic factory reset)
3) Charge port: There could be a short in your SubPBA, which will need to be replaced if that is the case.
4) Screen failure: There could be a short in your screen, causing a flicker when excess current is introduced to the device.
5) board level failure: a possible filter malfunction could be causing the issues. (to fix this you will need a multimeter, the Board Diagram -with indexes, and Surface mount soldering skills) if you do not have the required items and skills, then replacing the motherboard is also a solution.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Erick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 2,905
