Replaced display is dimming to dark
I replaced my display with an Ifixit replacement part and I did put in a new battery.
Everything worked fine (it is the 3rd time on this phone)
After a while I realized, that the display was showing some flickering which can barely be noticed.
I turned the brightness up and down to see if it would went away and then it got so dark that I couldn't turn it bright again.
After I finally got it back lighted I turned of the brightness adaption and rebooted several times.
When closing the phone everything seemed connected well.
There has been a screw - right above the Wifi-Cable connector which seemed loos and I tightened it.
Don't know what to check for.
The display goes dark, as soon as I turn down the brightness to 25-30%
この質問は役に立ちましたか?
