メインコンテンツにスキップ
2012年3月に発売されたオリジナルiPad2の改良版モデルです。より小さくなったダイプロセッサと再デザインされた内部構造が特長です。修理にはヒート(熱)を当てて、十分注意しながらこじ開けて行く作業が必須です。
73回答 すべてを表示
締切られた回答
Can a dead backlight be fixed with a logic board replacement?
I purchased an iPad 2 for extremely cheap on eBay. The problem was that the dock connector was so broken it was impossible to charge up. It was my first time doing such a difficult repair, and I'm pretty proud that I managed to open the iPad without ripping the wifi antenna (I put like 10 cracks in the digitizer though).
I was a bit careless and lazy, and didn't use a spudger (used a flat-head screwdriver) to disconnect the lcd and digitizer while replacing the dock connector, and now the backlight doesn't work.
When the iPad turned on, it became activation locked, and I'm waiting for a 'configuration locked' logic board to bypass and get a usable iPad.
My question is: With a new logic board, will the backlight issue be fixed, or is it more likely that the LCD's actual backlight was fried and I need a new LCD.
Happy holidays guys, thanks in advance for any responses.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
look to see if you pryed any components off, also activation can be taken off by removing either a cap or resistor
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It's clearly a backlight issue, nothing "pryed off" should make the backlight fail. Also, that removing a resistor from the motherboard is for 3G models only and mine is a Wi-fi model
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 54
