メインコンテンツにスキップ
車両やトラック用のスピーカー、ヘッダーユニット、CDプレイヤの修理ガイド。
247回答 すべてを表示
Why Doesn't my sub work with my headunit
I've recently wired a sub to my car and couldn't get the sub to work the wiring is all good but there is no sound to the sub the amp light is on the settings on my head unit for the sub are all good but still no sound, we tried my brother in laws head unit in my car and the sub worked fine then we tried my head unit in hes car and again no sound in hes sub, we sent the head unit back to pioneer thinking the rca ports were no good got a replacement one and still nothing will i have to get another head unit?
I have the Pioneer avh-295bt
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Hi @bayleighthomass ,
Just verifying that you have double checked that all the settings highlighted in the image below, especially the setting for switching the rear speaker output are correct.
(click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
Yes all that is what i have tried to do even with a factory reset and with the old and the new head unit.
さんによる
Seems too coincidental to have 2 faulty units.
When you say "the amp light is on" assume that you mean that you have an external power amp for the unit. Is this correct?
To me this means that your connections should be as per the "without internal amp" connections found on p.34 of the guide. Is this how you have it connected?
さんによる
Hi I also have a problem, I've try to find subwoofer off and on setting on my 9inch Android head unit but it didn't seem to have it listed on this unit. Place help it would be much appreciated.. Thanks
さんによる
@Tow Sok
What is the make and model number of the head unit?
さんによる
Pull the top menu down and make sure the amplifier button is highlighted.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Bayleigh Armstrong さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 46
過去 30 日: 255
今までの合計 22,442
