Why can't I get this open
Trying as hard as I can with the plastic tools I ordered, I still can't get the back of the case open.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @emcoy ,
Did you start at the headphone jack as recommended in the ifixit Kindle Fire HD 8.9インチのバッテリーの交換 guide and also to make sure the notch on the plastic opening tool is facing the back of the Kindle?
このアンサーは役に立ちましたか?
If all else fails, use a credit card.
May seem silly but it happens. Did you remove the sim tray first? Just like samsungs, they can give you a hard time during disassembly. If you're having some serious issues just utilize several picks to get it open, you may have a stubborn clip if it isn't the sim tray.
Good luck and don't break the cable
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 106
