jbl charge 3 and jbl xtreme pairing
I just upgraded jbl charge 3 and i cant pair it with jbl xtreme any more. How can i fix it?
There is no way I have the same problem the charge 3 once updated is connect+ and will never be able to connect to the xtreme bcs it's connect
このアンサーは役に立ちましたか?
Try to downgrade the firmware to a previous version. https://www.jbl.se/
このアンサーは役に立ちましたか?
I have the same problem as many others as well.
Yes downgrade sounds like an option. But how to do it? In the link you’re indicating, i can’t find something.
Or upgrading the Extreme to connect+ firmware, that i don’t think exists yet. Or ever.
Hi thre is no way to downgrade, once you updated.
The only solution is to wait JBL dares to release the upgrade for the Extreme.
In my way of thinking this should have been done already.
JBL is still selling Extreme with not clear info about connecting to other JBL.
After you get into the problem is when you see you are fu.... by JBL
過去 24時間: 0
過去 7 日: 10
過去 30 日: 46
今までの合計 34,333
Once you have upgraded the charge 3 to connect+ you can only connect it to other connect+ devices (like the Flip 4). You can no longer connect it to the Xtreme until that device is updated to connect+ (the Xtreme still runs on connect)
Laggelicious Laggelicious さんによる
