メインコンテンツにスキップ
The Stylo 2 (model number LS775), the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
82回答 すべてを表示
How can I remove unfortunately system ui has stopped working
How can I remove unfortunately system ui has stopped working but won't let me do anything else. Like log onto the phone
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 19
コメント:
What is the name of the app?
The link doesn't work on the computer.
さんによる
The dose not work I can't download any thing or delete no thing work just the sentence unfortunately the system UI has stopped
さんによる
How do I correct the ui malfunction on my straight talk service phone. It says it's stopped working and then a clock symbol says wait. It keeps showing up. I really don't wanna data reset my phone!
さんによる
My Tablet RCA say “Unfortunately System Ul has stopped. What can I do?
さんによる
Turn phone/ tablet off. INSTALL AN SD CARD .The Ui system stops working because it is overloaded with work, The SD card should take some of your files and apps. It chooses but you can ask it to take. more apps. When you turn phone on this process should start and Ui should be better
さんによる
4件以上のコメントを表示
コメントを追加
5件の回答
最も参考になった回答
WARNING: Use caution when undertaking this process. One wrong selection can wipe your phone.
Ive had this same phone since it came out and needed to do this once. Still kickin
  • Power off your Android device
  • Hold the volume DOWN and power button until the recovery menu appears
  • Press volume down until the word Recovery is highlighted, then press the power button to reboot into recovery.
  • You should now see a black screen. Hold down the power button and press the volume UP until you see the recovery menu.
  • Using the DOWN key, navigate until you have wipe cache partition highlighted. Press the power button to erase the system cache. Once the cache is cleared, use the volume DOWN button to navigate to reboot to bootloader, and press the power button. Your device should reboot back to the original menu (see in first picture). Using the volume down button highlight REBOOT and press the power button. Your device should now reboot into Android with a cleaned system cache and a much improved OS.
このアンサーは役に立ちましたか?
スコア 6
コメント:
None of these menus show up on sony xperia. Because it only blinked instead of something coming up at all. When I let go of the buttons it just started as normal again. Maybe it works better on android devices more similar to Samsung?
さんによる
none of that showed up on my phone it just says safe mode
さんによる
What if Recovery is not an option? Only have the following: Continue Power Up, Safe mode, USB debug mode, Factory data reset, Wipe cache, and Power down. Which of these, if any, should I choose. Thanks!
さんによる
I'm just guessing but maybe "Wipe cache" is the same one? I'm no expert, just sounds logical to me based on the words. :)
さんによる
i wipe the cache clean before my screen went blank still nothing very BAD BAD advise
さんによる
コメントを追加
To get back in from the black screen system ui provides press button and volume button together.This does not solve the problem just gets you back into the tablet.
このアンサーは役に立ちましたか?
スコア 1
コメント:
Should say power button
さんによる
Please explain the process that worked for you....
さんによる
コメントを追加
I had the same problem but now I solved it myself, it appears to me that no one talks about this method and they tell you to go to settings and blah blah blah!! They do not understand that the screen is black and cannot see anything! Others wants you to do a factory reset and cause you to lose your precious data! I have fully recovered my phone without any data loss!
このアンサーは役に立ちましたか?
スコア 0
コメント:
I don't know why but I have posted whole method but its not showing it
さんによる
can you please tell me how you did it? I am having the same issue with my samsung.
さんによる
My desktop is showing me that error UI has quit working how do I fix that
さんによる
コメントを追加
I had the same problem. but by trying to hold different buttons at the same time my phone restarted, and by doing that it fixed it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
only for the hard rest on power on batan and the waliam batan ap ya down open this next page enter option rest and next option no…no..no.yah yes option batan canfam batan yes rest starting……….. thanx for view
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stephanie Figueroa さん、ありがとうございました!
統計データを表示:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 105
今までの合計 37,559
