メインコンテンツにスキップ
Released March 2016, 7.0" Galaxy Tablet by Samsung.
47回答 すべてを表示
Why can't I update any apps?
My tablet does not have the Google play app on it. It is an SM-T280 I've tried doing a software update along with trying to download the app from my browser with no success. Without the play store, I can't seem to update apps, or install apps. Anyone have this problem also? Or know how to fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You likely have a model from mainland China.
The easiest away around this is to install the Amazon app store and use their store.
• go to Settings --> Security --> enable Apps from Unknown Sources.
• download amazon app store from https://www.amazon.com/gp/mas/get/androi...
• use the samsung file manager and install this apk
Otherwise, here is how to get Google Play Store.
• download http://www.apkmirror.com/apk/google-inc/...
To download each APK file, just click on the link, and then scroll down where you’ll see Download APK. Click that.
Install the above 4 files with the Samsung file manager in the following order:
Google Account Manager APK → Google Services Framework APK → Google Play Services APK → Google Play Store APK
You should see the play store on the home screen now.
All you have to do now is just tap on your new Google Play Store app, and sign in with your Google account.
You may find that it might not work at first, but it will be alright after you’ve signed in.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I have tried repeatedly to download the play store app itself and all I get is a little sign that says that it wasn't installed. It worked wonderfully for the amazon app but i was really hoping to get the Google play app :( the amazon app just doesn't have some of the stuff that Google does
さんによる
But thank you so much for the help
さんによる
@alexf1x1t, did you install all 4 files I provided in the exact order? If so, try a a different google play apk. Apparently, there are 4-5 variations. One of these should install.
https://www.apkmirror.com/apk/google-inc...
さんによる
コメントを追加
回答を追加する
alexbushell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 15
今までの合計 1,510
