Black Screen But I still have sound
How do I fix the problem of a black screen but still have sound
Frank Hay depending on your exact model and what you have checked. Most common failure would be the backlight circuitry on your power board. Check the caps on the board. After that you want to check your T-con board and your backlight LED array. Again, we do need an exact model number. It will also help if you post plenty of good images of your boards with your question. That will allow us to see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that
このアンサーは役に立ちましたか?
@oldturkey this one was orphaned but I fixed it after voting.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 332
