メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
79回答 すべてを表示
How do I deattach the motherboard?
I've spilled some sauce on the front of the calculator and want to remove the motherboard from it's frame (to acces the front). But it seems to be fixed to the frame with black plugs, which are not screws in any way. Is there no option to remove the motherboard?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Well, you technically can, but it's really hard, and your probably wont be able to get it back on the way it was. I believe there are some plastic pegs you need to break to remove it. It's also probably glued in some places.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Klaas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 321
