apple hi-fi won't work on mains, it only works on batteries.
Hi, my apple hi-fi won't work on mains supply, it only works on batteries. help
Hi @iain_sinclair ,
You will have to open the device and then check the connections from the mains power inlet to the motherboard.
Here is a link that hopefully may be of some help.
If you cannot see (or test, using a DMM- digital multimeter) what the problem is, take some close up pictures of the motherboard and perhaps someone will be able to help you further. Here's how to do that. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 250
7 件のコメント
Please explain. Do you mean it won't work on wall power?
Reed Crosby さんによる
yes, thats correct it won't work on wall power
Iain Sinclair さんによる
Have you tried a different outlet?
Aiden さんによる
yes tried different wall outlets and different power lead, the problem is with the apple unit.
Iain Sinclair さんによる
did you drop it before? anything happen before it broke?
Aiden さんによる
2件以上のコメントを表示
