メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Screen glitches, computer freezes, & ram must be reseated often
I've resorted to keeping my computer on a pedestal & using a wireless keyboard & mouse, so I never have to touch it except to gently plug the power in. Even so, multiple times a day, I encounter the same scenario: The computer freezes, the screen glitches with what look like a bunch of barcodes, then the telltale 3-beep. After reseating the ram, everything works fine, if a little slow. What once happened every few days, now occurs 3-5 times a day. I've searched online for replacement logic boards, but the ones that show up with my criteria don't look like the one in my computer. Thoughts?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Are the barcodes pink and go from top to the bottom of the screen or are they white and go from left to right of the screen?
さんによる
Hi, @jennessee had you tested your memory yet?
Try using apple diagnostic to test the hardware
さんによる
@anthonyj They are pink.
さんによる
@salmonjapan I replaced the memory, which seems to be a temporary fix. The problem doesn't happen as often. After a little more poking around, I have discovered that the top ram slot doesn't hold securely. It looks like I will need to replace the logic board after all.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Try testing your memory. If it comes back fine, you may need a new board. If not, I would consider finding the faulty stick(s) and replace them and see if it works. Good luck!
EDIT: Use Apple Memory Diagnostic
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jennessee Rosenberg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,963
