メインコンテンツにスキップ
All-in-one indoor security device released in 2015. The Canary CAN100USBK is a Wi-Fi enabled 1080p camera that comes with a 90 decibel siren.
3回答 すべてを表示
Disabling the LED light ring
Is there an easy way to disable the led light ring on the base of the unit please?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I just bought a All in one. Bummed that it does not work in a window looking outside due to IR lights glare. I also wondered about white light on bottom. Am thinking of covering it with electrical tape. Careful not to cover anything on the bottom. I did put tape over the IR lights, but that defeats the ability for night vision. I guess I am asking the device to do something it is not designed to do. Most likely will be returning it.
さんによる
Canaryman, what did you end up doing?
さんによる
コメントを追加
3件の回答
最も参考になった回答
If you mean the red one that you only see when it is kind of dark, I believe that is the night vision.
"Those small red lights around the CCTV cameras are called IR LED or simply infrared LED. They're used to supply lighting for security cameras to see in dark and low light conditions which are turned off at day
time." -Quora
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Thanks for your response Aiden but i meant the white ring on the underside of the unit which is a bit of a giveaway if anyone broke in.
さんによる
Well, keeping it would notify potential thieves that you have a camera and that could scare them off. Much like those signs people have in their yards to say they have an alarm system. those signs scare potential thieves away. just showing you have security measures set up could avoid a potential robbery! https://www.safewise.com/blog/do-fake-se...
さんによる
Thanks once again Aiden.
I would however like to know if there is a method to disable the light ring rather than whether it should be disabled or not.
さんによる
ah yeah. Sorry. according to the manufacturer's website, there's an app. but if you cannot disable it there, that's poor design on their part and you may have to cut a wire.
さんによる
If you don't want to permanently disable it Probably just cover it with duct tape.
さんによる
1以上のコメントを表示
コメントを追加
I found this: https://help.canary.is/hc/en-us/articles... maybe that couod help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
luz roja intermitente
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Canaryman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 8,119
