メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
Light sensor doesn't work, second cable (Original black screen)
Hi, I really need some help, I replaced the cable with the proximity sensor in order to fix the power button, then the microphone for videos and the proximity sensor didn't work. The second time, the proximity sensor still doesn't work!! This is really annoying, the cables seem to be high quality, I don't get it. I've tried restoring to 4.2.1, resetting all settings, hard resets. Any ideas??
It seems to be set well by the way, I've placed the black foam spacer over the sensors correctly I believe.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
I had the same problem as you. I didn't have all the spacers in at first and that was my problem. Just make sure that the proximity sensor is sitting all the way down against the glass so that the sensor goes straight out the glass. My problem was that there was a tiny gap between the sensor and the glass and it was not shooting out straight. Hope it works out for you.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hey, yeah I've noticed on subsequent iPhone 4s that there is a little rubber spacer, I figured i can't matter that much so I ignored it (hearing about different sensor models and such). But maybe this is right. The problem is that I no longer have the original little spacer, I'll have to make something. I'll post on here if that works.
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,721
