メインコンテンツにスキップ
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
220回答 すべてを表示
Touchscreen not working after digitizer replacement
I replaced my digitizer because the glass was cracked. The new digitizer looks very different on the connector part.
New piece:
http://i63.tinypic.com/2a4y77r.jpg
Old piece:
http://i66.tinypic.com/2vc6ql3.jpg
I tried connecting the new piece. The home button works, but not the touchscreen. If I try to use again the old digitizer, everything works fine.
My question is:
as far as you know, is the new piece even compatible with my Ipad mini 2 (model 1490)? When I bought it, the description said it was for that model too.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I think the issue is there isn't any or sufficient shielding to the ribbon cable and digitizer border.
See how the old piece has some taping, it's minimal but could have more taping.
The new piece needs that yellow kapton tape around here:
Additionally you could wrap it around the yellow marked area at the ribbon cable that plugs into the logic board to keep it nicely in place.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Thank you. I didn't plan on buying kapton tape, but when I did it worked. At the beginning I was trying to use the tape from the old screen, but there wasn't enough for the connector part.
Thank you very much, again :)
さんによる
コメントを追加
回答を追加する
Elle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,716
