メインコンテンツにスキップ
2012年3月16日に発表されたiPadの第3世代モデルです。4GとWi-Fiモデル用の修理ガイドを公開しています。修理には温めて慎重にこじ開ける作業が必須です。
Digitizer/touch doesn't work after replacement
So, we have and iPad 3 where the screen got busted. Ordered the replacement from iFixIt, and put my tech-genius 16 year old on the job (he's replaced numerous iPhone and iPad screens in the past). Unfortunately, he DID make one rookie mistake—he sealed the screen back before making sure everything worked. *sigh*
We powered it on, and lo and behold, no touch. It powers on and looks great. Just no response to touch.
It DID work with the old broken screen, so I'm fairly confident it's not a logic board issue. Any thoughts?
If I pull this screen off to double check connections, I won't have any way to seal it back up, right? So do I have to order a whole new kit?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
If you don't have B7000 liquid glue already, get some. You'll thank me later.
It is very useful in many sorts of applications when you want to stick screens down. Assists with screen adhesive (if the one on the screen is not good enough).
Easy to remove, easy to clean off.
さんによる
コメントを追加
1 件の回答
ベストアンサー
you can lift the digitiser back off and use 3m double sided tape to stick if back down, if lifted off clean enough there maybe enough adhesive that if you add some heat it might adhere again. you will need to take it back off anyway to see if its a bad connection or bad digitiser
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Wes Comer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 281
