メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
My new screen turned black after ten second from replace it!
Hi
First of all excuse my bad English, I replaced my screen and i followed the instructions step by step and the screen worked for like ten second and turned black, everything else work, the touch on the screen is working , the touch ID is working, the front camera is working( how did I know? I connect my phone to my mac and with quick player you can see your phone through your mac), I restart my phone and didn't work, I reconnect the screen cables and power cycle my phone. still doesn't work, so can you help me?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
saeed if you didnt disconnect the battery when replacing the screen you could have blown the backlight filter on the board
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Screen isnt turning on? try the order of operations below that my technicinans all follow!
By following the steps below, you agree not to hold myself, or the website responsible for any damage to self, device, or surrounding objects, that improperly handling your phone may cause. These steps will also assume you have the required tools to do repairs, where as else, it would make no sense to ask for instructions.
1) Hard Reset: Hold the home, and lock button down together for 15-20 seconds, or until you see the apple logo. if you get the apple logo, great! if not, continue
2) Data restore: Plug the device into the computer. (preferrably one it has been plugged into before) make sure the device is recognized by USB. check what the device reads as on iTunes. If it gives you the option to restore the device up front, then do so immediately. should it read fine as a phone, then continue
3) Loose connectors: Disconnect the screen, clean the connectors with Isopropyl 99% rubbing alcohal, and a new toothbrush. Then reconnect the screen. Should this fix the issue, great! if not, continue
4) Excite The Battery: Hit the + and - of the device with an external power supply for approximately 30 Seconds to 1 Minute. (This power supply MUST be of the proper voltage and amperage of which the battery will accept, otherwise injury may occur. these Specs can be found written on the battery itself) This repair requires specialized power supplies, and if done without it, may cause property damage or physical harm
The next steps require parts, and will not be free of charge
5) Check the board for physical damage: Scan the board (Preferrably under a 10X+ Microscope) for cracked, chiped, blown, or missing components. replace any problmatic components.
6) Battery: Replace the battery, if this fixes your issue, Great! if not, continue
7) Screen Replacement: Replace the display assembly. If this fixes your issue, great! if not, continue
8) Logic board replacement: You will need to replace the logic board in the device. this will fix your failure.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I tried the new screen on another iPhone and it worked so what do you think ?
さんによる
there is a posability of a board short causing the GPU to have fried. if it doesnt work on one phone, but works on another, it is likely an issue with something inside the first.
さんによる
the old screen was working, it just was glass broke, the problem happened after I did the replacement I tried the old screen and doesn't work any more just black screen, so what do you think?
さんによる
then something blew on the board for sure. step 8
THIS IS ASSUMING YOU DID STEP 1
さんによる
コメントを追加
回答を追加する
Saeed Khader さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 60
