Why is iPhone running hot
iphone running hot after screen replacement.what shoud I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Does everything else work properly?
It could be related to your replacement screen. You could re-install the original screen if it still works (even though it may be cracked) just to see if the problem is still there. If the phone still gets hot with the original screen, you should inspect the screen connectors on the logic board to see if there is any debris or damage.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 49
