Sony Casette Deck Heads won’t turn
I’ve just bought a Sony TC—wr445 casette deck and it won’t turn the tape, when I try to play it makes clicking sounds, belts are all in tact
@jonp123 you have to try and isolate the area where the clicking noise is coming from and let us know. This should help with the disassembly
Also inspect all your boards for any damaged looking (leaking or domed capacitors etc.) post some images of your boards with your question so we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that
このアンサーは役に立ちましたか?
Hello Jon,
I had the same problem with my Sony TC-WR445 cassettedeck.
I found the solution on http://www.tapeheads.net/showthread.php?...
with kind regards
Bertil
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 13
過去 30 日: 26
今までの合計 2,843
1件のコメント
I added the video of the clicking
Jon Pasternak さんによる
