Why won't my charger work
Every time I try to charge to I have to shove the charger in and push up cause its refusing to charge.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try a different charger cable, if that fails, try a different USB block, if that fails, try a different outlet or computer that is powered on.
OK then. So you can order a new charging port assembly here: https://www.amazon.com/Highfine-Charger-...
And then follow this guide: Asus ZenFone 2 Motherboard Replacement up to step 8.
Good luck!
このアンサーは役に立ちましたか?
Its not the charger its the phone plug in the middle a metal piece is shoved upwards and i cant get it to be in the right spot for my phone to charge
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 947
