Will replacing just the logic board remove icloud lock?
If I remove all the necessary chips from my current icloud locked iphone 6 logic board and put them on a new empty logic board, will it still remove the icloud lock?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes, that is the idea.
However, this requires a lot of expensive equipment and a lot of advanced soldering skill.
See this video.
このアンサーは役に立ちましたか?
Yes, that will remove the iCloud and that's what I did already on one iPad.
You mostly need patience and a lot of attention when removing the digitizer with a heatgun cause it's fragile, but yes, it be different on an iPhone and might need some soldering skills .
このアンサーは役に立ちましたか?
Hi i was just wondering bc i have a icloud locked iPhone i am going to do the hardware method but i have one question do i need to take the chips that are on the logic board onto a new logic board or can.i just buy a new logic board and install it into the phone thanks.
このアンサーは役に立ちましたか?
That good to know better than old way by using website to remove icloud lock
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 8,568
