メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1236回答 すべてを表示
Unable to flash iOS (Different errors on 3u and iTunes
Hi,
Wondered if someone could help me.
My iPhone 5c wont flash with 3uTools as it comes up with
ERROR: Unable to restore iDevice(-1).
Its at 80% on updating baseband
With iTunes it says
The iPhone "iPhone" could not be restored. An unknown error occurred (50).
I am using a genuine apple USB to my PC.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
IPhone stop's flashing at 16% no error, but just loading
さんによる
c39r5ec6grx4
さんによる
コメントを追加
5件の回答
ベストアンサー
Is there a reason you were trying to flash your iPhone? Normally, a -1 error is baseband related and this could be indicative of a damaged baseband IC or it's solder connections. Has the phone been dropped much over its lifespan? Has it come into contact with water?
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I was updating iOS and it didn't complete.
It apparently took a flight down some stairs.
さんによる
Then it's highly likely there is a bad solder joint on the baseband chip. A micro solder should be able to fix it by reflow / reball.
さんによる
コメントを追加
Error -1 on 3uTools may be caused by USB cable connection, network and baseband.
Try to change the usb cable, confirm the network connection. If error still exists, you would need to change the baseband.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
さんによる
コメントを追加
I have same problem!
I changed my screen replacement and battery, after this operation was succesfull the device.
But after while i did software update, it is crashed i mean the system trying rebooting all the time but nothing else.
I did it with itunes connection, i called the apple support but they didn’t helped what is the problem. I don’t remember the error code, but my phone can’t boot.
I turned off the find my phone and logout from device.
The flash with 3uTools it’s going to 19% and over.
Anybody help?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have the same problem I bet it is a bad connection I am going to open it back up and check to see if I did not put a connector on correctly
さんによる
have the same problem 3utools stuck at 19%
さんによる
コメントを追加
I’m using 3utolls for flashing iphone but my iphone is connected with 3utools but flash and jailbreak option show network connection error. Anybody tell me what am i do.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Change your firmware source and redownload it then restore again
さんによる
コメントを追加
Hi i am iphone 7 plus flash i flash errilla -53 u have 60 percent may i guide my guide
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jaymie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 22
過去 30 日: 93
今までの合計 26,718
