メインコンテンツにスキップ
Also known as the Moto G3—an Android smartphone released by Motorola in July 2015. It serves as an economical alternative to Motorola's flagship phones. Model XT1540 in the US, with dual-sim and "Turbo Edition" variants sold in other regions.
89回答 すべてを表示
How am I able to fix my phone when it's not charging?
I'm experiencing difficulties with my phone- I've tried checking the charger itself and the USB pocket- but it still won't charge. Does this mean I might have to replace my phone?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@sammiekins123 since you already checked the most common parts, replace the battery next. That way you have a known-good starting point should further troubleshooting be necessary. If that does not work, the you will have to take your phone apart. Check to see if the USB port is still properly connected and measure the voltage on the plug end with the charger plugged into the phone. Also , check the voltage on the battery connector with the phone plugged into the charge. Let us know what that voltage is.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Samantha M. さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 1,468
