メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1232回答 すべてを表示
Stuck in DFU mode and cannot successfully recover
So I have a iPhone 5c here, and it is stuck in DFU mode. I have tried recovering it with itunes, it gets as far as a apple logo with a empty progress bar and then it just stays like that. I have let it sit overnight and it still is stuck on empty recovery bar. If I do any combination of buttons, like holding home button and plugging in, hard reset, enter DFU mode, it will always get stuck in DFU mode. I am very confuzzled at this point... please help.
I have a computer at ready.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Ive seen this numerous times, it'll fail the restore at various points, its usually down to either the lightning port, battery or failure of the NAND. I usually lay a known good battery on top of the old one, and plug a new lightning port in with cable already attached, and then power on if the restore fails then its down to the NAND being faulty.
さんによる
So I probably need a new lightning port?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Try this first.
1) Download the full firmware from http://www.iclarified.com/750/where-to-d...
2) Plug the phone which is in DFU mode in to iTunes
• on PC, hold SHIFT+Click Restore, and select the firmware above
• on Mac, hold Option+Click Restore, and select the firmware above
If this still fails, try using 3uTools to update the firmware.
http://www.3u.com/
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank You! I cannot attempt until I reassemble it with a new battery so if it works, I'll get back to you!
さんによる
@avanteguarde I'm going to try this on an ipad mini (original) GSM with this website: http://www.iclarified.com/8500/where-to-... if it works, you get credit.
さんによる
コメントを追加
回答を追加する
Aiden さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 483
