メインコンテンツにスキップ
A series of 40 inch LCD HDTVs by Sony.
193回答 すべてを表示
How can I fix my pressure damaged TV?
Hi, I have a Sony bravia flat screen TV and while bringing it into my house I accidentally applied pressure to the screen. The screen is now slightly curved inwards with some light shadowing in some places on the top, as well as circular lights shining through in the center. It's quite noticeable but tolerable. Certain scenes in a TV show make it more noticeable while others not so much. I'm wondering if there's any way I can fix this or at least ease the problem.
Photos provided:
https://ibb.co/euKbA6
https://ibb.co/gU6dOR
Showing the top of the screen looking up.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Julia Goede there is but it is not easy. You would have to take the whole display panel apart. It can be done but it is tedious. You would have to be organized to keep the screws for the frame as well as the diffuser sheets strictly organized. It looks like ( sorry but some of the images are a bit fuzzy) like the diffuser sheets are a bit bend. Those are "translucent plastic pieces" that diffuse the light. The multiple round lights in the middle of the screen are from a light you used to take the pictures or are those showing from inside the panel. If so then some of the caps may be off from the backlight LED's. Again, if you can take the complete panel apart, this can be fixed. If you are up to it, let us know. Take plenty of pictures for each step so we can follow you along and give you advice as needed. You can post your pictures with your question y using this guide iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Julia Goede さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 5,686
