Why won't the Oontz Angle 3 speaker connect with PC Bluetooth?
The connection worked previously, I have no idea what has changed.
The PC sees the speaker, but the speaker doesn't play.
I tested the PC with AUX cable which works, I am also able to connect the speaker through Bluetooth on my phone.
I have checked all my PC settings and have no idea what else to look.
Help!
This happened to me, too, recently. Just after updating my PC, the Oontz Angle 3 would only be recognized as "Bluetooth Headset" and would fail to connect.
I have obviously removed the Oontz Angle Device 3 and tried to reconnect it.
I have also deleted/reinstalled any/all Bluetooth drivers on my computer.
The Oontz connects perfectly well on my iPhone, however.
What is going on?
Ben S さんによる
I still don't know the reason, but it worked for me when I uninstaled the speaker and installed it again. It happened to me a few times the Bluetooth connection didn't work without this "manual reset". So, go to devices, installations, and remove and then again add the speaker. I hope this helps you too!
Kristina Bogataj さんによる
