メインコンテンツにスキップ
モデル番号はA1040/10、15、20、30もしくは40GBハードドライブ/タッチホイールの上に4つの感知式LEDバックライトボタン
97回答 すべてを表示
Replaced battery but iPod still doesn't charge
I recently replaced the battery in my 3rd Generation iPod (A1040 20GB). It briefly powered up, worked and played music but the battery was low on charge and it quickly died. However, when I connected it to a wall charger it wouldn't charge. I have the same result when I connect it USB to a computer. I've tried several different kinds of wall chargers with the same results. When I plug it in it will briefly flash the Apple logo then go to a battery icon with a triangle with an exclamation point in it. I appreciate any help.
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
最も参考になった回答
Are you trying to charge it via USB? You need to use a 30-pin to firewire cable and charger, or an iPod dock. The 3rd gen iPod can’t charge with a USB cable like the other iPods can.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Have you tried replacing the charging port?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have not. I'll explore that option, thanks for your response.
さんによる
コメントを追加
You can either try a MB with the charge port already on it or a new charge port by soldering. But that's the next step. It's been hard finding main boards for these these days though
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
By "MB" are you referring to the logic board? (IF192-001-1).
さんによる
Yes that's what I meant . MB short had for main board
さんによる
コメントを追加
I have this same issue.
I found two burnt out chips next to eachother on the motherboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I’m having the same problem with my 15GB model, I’m thinking of replacing the dock connector and cleaning up the motherboard to avoid any possible shorting. You could try this:
Connecting the iPod to the FW charger without the battery (open up the iPod and disconnect the battery), if it turns on then the battery might be faulty.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
what is the fw charger i have one of these took the battery out was wondering if it could be hard wired to bypass the battery.
さんによる
コメントを追加
回答を追加する
Brian Martin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 23
今までの合計 417
