メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
Only have motherboard. Need everything else.
As the title says, I only have the motherboard & battery from my galaxy s3 and need all the other parts. Should i buy them all separately or would it be cheaper to buy a new s3 and do a board swap?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
If you look on ebay or amazon you can probably find a parts phone if you find one that needs a motherboard it would be cheaper . broken phones are often sold in lots for cheap
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@nickolair it would be a lot cheaper and easier if you buy a used replacement and then just transplant your motherboard. At least that way you know that you will have all the parts you'll need with one purchase. Use this guide Samsung Galaxy S III Motherboard Replacement for the repair
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
@oldturkey03, out of curiosity, what does it mean when someone accepts the answer, but when you look at the list of questions, it says "answer unaccepted", but it is marked green and accepted?
さんによる
@avanteguarde really not sure. You have an example?
さんによる
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 40
