メインコンテンツにスキップ
The fourth generation Volkswagen Jetta, also called the MK4 or the Bora, is Volkswagen's family sedan.
85回答 すべてを表示
Power locks operating poorly with key fob - poor range
I have a 2005 1.8t Jetta GLS wagon with over 133000 miles.
Problem: The key fob range is limited. I must use the key fob from no farther than three to five feet from the driver door in order to unlock, lock or operate the trunk with the key fob.
I have replaced the battery in the key fob.
What else can I do to solve this problem?
The electric trunk hatch opening motor seems to be sluggish as well.
Thanks ifixit community!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This problem can usually be solved by cleaning the circuit board of the key fob.
The board inside your remote can get a lot more filthy than you think! When the board is dirty it can prohibit the contact to the circuit board when you push down on the button.
Simply wiping the circuit board off can make your key fob like new again!
Here is a video on how to clean your key fob circuit board
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Woody Wiest さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 51
