メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
78回答 すべてを表示
My calculator won't charge and I replaced battery, still won't charge.
My calculator won't charge and I've replaced the battery and I've used the usb cable the calculator comes with to try and charge it. Still nothing. What do I do to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
I'm sorry I've never heard of this issue before. My only solution is to push the cable into the calculators USB port harder, this solution is usually only good for data transfer issues. When you put the fresh battery into the calculator did it turn on and operate normally? (besides not charging). Other than that, it sounds like a hardware failure or defect to me. You'll probably have to return it.
さんによる
コメントを追加
1 件の回答
Check that the battery is in good condition and that it's making proper connection to the board. The only other thing I would suggest is open it up, inspect the charging port, if all looks good try using another cable if not either try to replace the port if it's faulty or return the item.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maha Mohammad さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,719
