メインコンテンツにスキップ
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146回答 すべてを表示
Replacement 16mp rear camera is unfocused and "nodding"
The replacement camera focus is stuck and blurry, the quality looks arguably worse, and it "nods".
When I hold the camera still, the camera shifts downwards then back to the centre (when holding portrait-view-- left/right in landscape). You can see the camera lens move if you look directly at it.
I'm not sure what to do to fix this, or did I get a faulty one? When I opened the package, the camera was at the bottom of the box and not cushioned in-between the packing material so could it have been damaged during shipping.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi Kimberly,
That camera sounds like it's damaged, so you should consider returning that one and getting a new one.
- Jasen
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi Kimberly, I had the same problem until I reboot the cellphone with factory settings a few minutes ago. It now works perfectly fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kimberly Fong さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 14
今までの合計 622
